To avoid traffic interruption, you can enable alternative routes globally to replace the best route with the next-best route, if the best route becomes unavailable.
The concept of alternative route applies between routing protocols. For example, if an OSPFv3 route becomes unavailable and an alternative RIPng route is available, the system activates the RIPng route immediately without waiting for an update interval to expire.
By default, the alternative routes feature is globally enabled on the switch.
The following example demonstrates this behavior.
In this example, you configure OSPFv3 and RIPng routes on two switches, Switch-1 and Switch-2, as shown in the following table.
Table 1. Switch configuration
Configuration Switch-1 Switch-2
VLAN ID 2 2 and 3
IPv6 address 2000:0:0:0:0:0:0:1/64
VLAN 2: 2000:0:0:0:0:0:0:2/64
VLAN 3: 3000:0:0:0:0:0:0:2/64
Protocols OSPFv3 and RIPng OSPFv3 and RIPng
VLAN port members 1/5
VLAN 2: 1/5
VLAN 3: 1/6
Switch-1 Configuration
On Switch-1, configure VLAN 2 and the IPv6 interface address 2000:0:0:0:0:0:0:1/64.
Switch1:1:1>enable
Switch1:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch1:1(config)#vlan create 2 type port-mstprstp 0
Switch1:1(config)#vlan members 2 1/5
Switch1:1(config)#interface vlan 2
Switch1:1(config-if)#ipv6 interface address 2000:0:0:0:0:0:0:1/64
Switch1:1(config-if)#ipv6 interface enable
Switch1:1(config-if)#exit
Switch1:1(config)#show vlan basic
                          Vlan Basic
VLAN                        MSTP
ID    NAME     TYPE         INST_ID PROTOCOLID   SUBNETADDR    SUBNETMASK  VRFID ORIGIN
1     Default  byPort       0       none         N/A           N/A         0     CONFIG
2     VLAN-2   byPort       0       none         N/A           N/A         0     CONFIG
All 2 out of 2 Total Num of Vlans displayed
Switch1:1>show vlan members
                                   Vlan Port
VLAN PORT               ACTIVE             STATIC             NOT_ALLOW
ID   MEMBER             MEMBER             MEMBER             MEMBER
1    1/1-1/4,1/6-      1/1-1/4,1/6-
     1/24              1/24
2    1/5               1/5
All 2 out of 2 Total Num of Port Entries displayed
Switch1:1(config)#show ipv6 interface vlan 2
                           Vlan Ipv6 Interface
IFINDX VLAN PHYSICAL          ADMIN   OPER  TYPE  MTU  HOP REACHABLE RETRANSMIT MCAST   IPSEC    RPC      RPCMODE
INDX        ADDRESS           STATE   STATE            LMT TIME      TIME       STATUS
2050   2    b0:ad:aa:4e:59:00 enable  up    ETHER 1500 64  30000     1000       disable disable  disable  existonly
                               Vlan Ipv6 Address
IPV6 ADDRESS                            VLAN-ID      TYPE    ORIGIN    STATUS        NAME
2000:0:0:0:0:0:0:1/64                   V-2          UNICAST MANUAL    PREFERRED
fe80:0:0:0:b2ad:aaff:fe4e:5900/64       V-2          UNICAST LINKLAYER PREFERRED
1 out of 1 Total Num of Interface Entries displayed.
2 out of 2 Total Num of Address Entries displayed.
Configure port 1/5.
Switch1:1(config)#interface gigabitEthernet 1/5
Switch1:1(config-if)#encapsulation dot1q
Switch1:1(config-if)#no shutdown
Configure IPv6 globally.
Switch1:1(config)#ipv6 forwarding
Switch1:1(config)#show ipv6 forwarding
        Ipv6 forwarding - GlobalRouter : enable
        ecmp                           : disable
        ecmp-max-path                  : 1
Configure OSPFv3 on the VLAN.
Switch1:1(config-if)#ipv6 ospf area 0.0.0.0
Switch1:1(config-if)#ipv6 ospf enable
Switch1:1(config-if)#show ipv6 ospf interface vlan 2
        admin-status         : enable
        area                 : 0.0.0.0
        dead-interval        : 40
        hello-interval       : 10
        metric               : 1
        poll-interval        : 120
        priority             : 1
        retransmit-interval  : 5
        transit-delay        : 1
        type                 : BROADCAST
Configure OSPFv3.
Switch1:1(config)#router ospf ipv6-enable
Switch1:1(config)#show ipv6 ospf
                   OSPFv3 Global Information - GlobalRouter
        router-id                      : 170.78.88.0
        admin-state                    : ENABLED
        version                        : 3
        area-bdr-rtr-state             : FALSE
        as-bdr-rtr-state               : FALSE
        helper-mode                    : ENABLED
        as-scope-lsa-count             : 0
        lsa-checksum                   : 0
        originate-new-lsas             : 22
        rx-new-lsas                    : 11
        ext-lsa-count                  : 0
Switch1:1(config)#show ipv6 ospf neighbor
                        OSPF Neighbor - GlobalRouter
IFINDX(VID/BRT/CLIP) NBRROUTERID     NBRIPADDR                               STATE     TTL
2050      (2)        170.78.84.0     fe80:0:0:0:b2ad:aaff:fe4e:5500           Full      31
1 out of 1 Total Num of Neighbor Entries displayed.
                      OSPF Virtual Neighbor - GlobalRouter
NBRAREAID       NBRROUTERID     VIRTINTFID NBRIPV6ADDR                STATE
0 out of 0 Total Num of Virtual Neighbor Entries displayed.
                               OSPF NBMA Neighbor - GlobalRouter
INTERFACE NBRROUTERID     NBRIPADDR                                STATE
0 out of 0 Total Num of NBMA Neighbor Entries displayed.
H = Helping a Restarting neighbor
Configure RIPng on the VLAN.
Switch1:1(config-if)#ipv6 rip
Switch1:1(config-if)#ipv6 rip enable
Switch1:1(config-if)#show ipv6 rip interface
Total RIPng interfaces: 1
                 RIPng Interface - GlobalRouter
IFINDX         COST     POISON       SEND         ADMIN        OPER
                        STATUS       DEFAULT      STATUS       STATUS
2050 (2    )   1        disable      disable      enable       enable
1 out of 1 Total Num of RIPng interfaces displayed
Configure RIPng globally.
Switch1:1(config)#router rip ipv6-enable
Switch1:1(config)#show ipv6 rip
               RIPng Global - GlobalRouter
                   Rip : Enabled
         HoldDown Time : 120
      Timeout Interval : 180
           Update Time : 30
   Default Info Metric : 1
    Default Info State : Disabled
 Default Import Metric : 1
Switch-2 Configuration
On Switch-2, configure VLAN 2 and VLAN 3 with the IPv6 interfaces 2000:0:0:0:0:0:0:2/64 and 3000:0:0:0:0:0:0:2/64 respectively.
Switch2:1>enable
Switch2:1#configure terminal
Switch2:1(config)#vlan create 2 type port-mstprstp 0
Switch2:1(config)#vlan members 2 1/5 portmember
Switch2:1(config)#interface vlan 2
Switch2:1(config-if)#ipv6 interface address 2000:0:0:0:0:0:0:2/64
Switch2:1(config-if)#ipv6 interface enable
Switch2:1(config-if)#ipv6 forwarding
Switch2:1(config-if)#exit
Switch2:1(config)#vlan create 3 type port-mstprstp 0
Switch2:1(config)#vlan members 3 1/6 portmember
Switch2:1(config)#interface vlan 3
Switch2:1(config-if)#ipv6 interface address 3000:0:0:0:0:0:0:2/64
Switch2:1(config)#show vlan basic
                           Vlan Basic
VLAN                        MSTP
3     VLAN-3   byPort       0       none         N/A          N/A          0     CONFIG
All 3 out of 3 Total Num of Vlans displayed
Switch2:1(config)#show vlan members
                                   Vlan Port
1    1/1-1/4,1/7-1/24    1/1-1/16,1/7-1/24
2    1/5                1/5
3    1/6                1/6
All 3 out of 3 Total Num of Port Entries displayed
Switch2:1(config)#show ipv6 interface vlan
                         Vlan Ipv6 Interface
2050   2    b0:ad:aa:4e:55:00 enable  up    ETHER 1500 64  30000     1000        disable  disable  disable  existonly
2051   3    b0:ad:aa:4e:55:01 enable  up    ETHER 1500 64  30000     1000        disable  disable  disable  existonly
                               Vlan Ipv6 Address
2000:0:0:0:0:0:0:2/64                   V-2          UNICAST MANUAL    PREFERRED
fe80:0:0:0:b2ad:aaff:fe4e:5500/64       V-2          UNICAST LINKLAYER PREFERRED
3000:0:0:0:0:0:0:2/64                   V-3          UNICAST MANUAL    PREFERRED
fe80:0:0:0:b2ad:aaff:fe4e:5501/64       V-3          UNICAST LINKLAYER PREFERRED
2 out of 2 Total Num of Interface Entries displayed.
4 out of 4 Total Num of Address Entries displayed.
Configure ports 1/5 and 1/6.
Switch2:1(config)#interface GigabitEthernet 1/5
Switch2:1(config)#encapsulation dot1q
Switch2:1(config)#no shutdown
Switch2:1(config)#interface GigabitEthernet 1/6
        ecmp                           : disable
        ecmp-max-path                  : 1
Configure OSPFv3 on the VLANs.
Switch2:1(config-if)#ipv6 ospf area 0.0.0.0
Switch2:1(config-if)#ipv6 ospf enable
Switch2:1(config-if)#show ipv6 ospf
        router-id                      : 170.78.84.0
        version                        : 3
        lsa-checksum                   : 0
        originate-new-lsas             : 56
        rx-new-lsas                    : 62
        ext-lsa-count                  : 0
Switch2:1(config-if)#show ipv6 ospf interface
Total ospf areas: 1
Total ospf interfaces: 2
                          OSPF Interface - GlobalRouter
IFINDX(VID/BRT/CLIP) AREAID          ADM IFSTATE  METRIC PRI DR/BDR       IFTYPE
2050  (2        )  0.0.0.0         ena BDR      1      1   170.78.88.0  BROADCAST
                                                       170.78.84.0
2051  (3        )  0.0.0.0         ena DR       1      1   170.78.84.0  BROADCAST
                                                       0.0.0.0
2 out of 2 Total Num of ospf interfaces displayed
Total ospf virtual interfaces: 0
                     OSPF Virtual Interface - GlobalRouter
AREAID          NBRIPADDR       STATE
0 out of 0 Total Num of ospf virtual interfaces displayed
Switch2:1(config-if)#show ipv6 ospf neighbor
2050      (2)        170.78.88.0     fe80:0:0:0:b2ad:aaff:fe4e:5900 Full      30
Configure OSPFv3 globally.
Switch2:1(config)#router ospf ipv6-enable
        version                        : 3
        lsa-checksum                   : 0
        rx-new-lsas                    : 11
        ext-lsa-count                  : 0
Configure RIPng on the VLANs.
Switch2:1(config-if)#ipv6 rip
Switch2:1(config-if)#ipv6 rip enable
Switch2:1(config)#
Switch2:1(config)#show ipv6 rip interface
Total RIPng interfaces: 2
2051 (3    )   1        disable      disable      enable       enable
2 out of 2 Total Num of RIPng interfaces displayed
Switch2:1(config)#router rip ipv6-enable
                   Rip : Enabled
         HoldDown Time : 120
           Update Time : 30
Viewing Route and Alternative Route Configuration on the Switches
On Switch-1 and Switch-2, the route 3000:0:0:0:0:0:0:2/64 is learned using the protocols RIPng and OSPFv3. The OSPFv3 route is learned as the best route because of its route preference value of 20. The RIPng route is added as alternative route because it has the route preference 100, which is greater than the OSPFv3 route preference of 20. On Switch-2, the route 3000:0:0:0:0:0:0:2/64 is a local route.
View route and alternative route configuration on Switch-1.
Switch1:1(config)#show ipv6 route alternative
                           IPv6 Routing Table Information - GlobalRouter
Destination Address/PrefixLen  NEXT HOP                    VID/BID/TID  PROTO   COST  AGE TYPE PREF
2000:0:0:0:0:0:0:1/64          39-4900-24XE                    V-2       LOCAL   1     0   B    0
3000:0:0:0:0:0:0:2/64          SwitchXYZ                       V-2       OSPF    2     0   B    20
3000:0:0:0:0:0:0:2/64          SwitchXYZ                       V-2       RIP     2     0   A    100
3 out of 3 Total Num of Route Entries displayed.
TYPE Legend:
A=Alternative Route, B=Best Route, E=Ecmp Route
2 out of 2 Total Num of Route Entries displayed.
TYPE Legend:
View route and alternative route configuration on Switch-2.
Switch2:1(config)#show ipv6 route alternative
2000:0:0:0:0:0:0:2/64          39-4900-24XE                     V-2          LOCAL   1     0   B    0
3000:0:0:0:0:0:0:2/64          SwitchXYZ                        V-2          LOCAL   2     0   B    20
3000:0:0:0:0:0:0:2/64          SwitchXYZ                        V-2          LOCAL   2     0   A    100
TYPE Legend:
Switch2:1#show ipv6 route
3000:0:0:0:0:0:0:2/64          SwitchXYZ          V-3          LOCAL   1     0     B    20
TYPE Legend:
Changing the Route Preference on Switch-1
On the switch, default preferences are assigned to all standard routing protocols. You can modify the global preference for a protocol to give it a higher or lower priority than other protocols. When you change the preference for a static route, if all best routes remain best routes, only the local route tables change. However, if changing the protocol preference causes best routes to no longer be best routes, neighboring route tables can be affected.
In the following example scenario, you configure a different routing preference for the RIPng protocol on Switch-1 and observe the learning of best and alternative routes. The existing route preference for RIPng is 100.
Switch1:1#show ipv6 route alternative
TYPE Legend:
TYPE Legend:
Configure a different route preference for the RIPng protocol, for example, 19.
Switch1:1(config)#ipv6 route preference protocol ripng 19
Switch1:1(config)#exit
Verify the route preference configuration.
Switch1:1#show ipv6 route preference
                             IPv6 Route Preference - GlobalRouter
PROTOCOL        DEFAULT    CONFIG
LOCAL           0          0
STATIC          5          5
SPBM_L1         7          7
OSPFv3_INTRA    20         20
OSPFv3_INTER    25         25
EBGP            45         45
RIPNG           100        19
OSPFv3_E1       120        120
OSPFv3_E2       125        125
IBGP            175        175
View the updated route preference (for RIPng) on Switch-1. The RIPng route is now learned as the best route because its route preference value (19) is lower than that of OSPFv3 (20), as shown here.
3000:0:0:0:0:0:0:2/64         SwitchXYZ                        V-2          RIP   2     0   B    19
TYPE Legend:
3000:0:0:0:0:0:0:2/64           SwitchXYZ                          V-2          OSPF    2     0     A    20
TYPE Legend:
Disabling Alternative Route Learning on Switch-1
The following example demonstrates disabling alternative route learning on Switch-1.
View the alternative routes on Switch-1.
TYPE Legend:
Disable IPv6 alternative routes on Switch-1.
Switch1:1(config)#no ipv6 alternative-route
Verify that alternative route learning is disabled.
Switch1:1#show ipv6 global
        forwarding                     : enable
        default-hop-cnt                : 64
        number-of-interfaces           : 1
        icmp-error-interval            : 1000
        icmp-error-quota               : 50
        icmp-unreach-msg               : disable
        icmp-echo-multicast-request    : enable
        static-route-admin-status      : enable
        alternative-route              : disable
        ecmp                           : disable
        ecmp-max-path                  : 1
        source-route                   : disable
TYPE Legend:
Verify that the alternative route (RIPng) is not learned.
TYPE Legend:
